Hi
The MAX17526AATP+T datasheet is recommending to use 2.2MOHM resistor as the high side resistor of the voltage divider for the OVLO and the UVLO pins.
The problem is that when we try to measure the value at these pins the systems is turned off probably due to current divider to the DMM which turns significant when using 2.2MOHM resistors.
My question is, do we have to use this value (2.2MOHM)?
