Clarification on CFF Value for LTM4624 at 0.7V Output
Product Number: LTM4624
I am using the LTM4624 micromodule regulator with a 5V input and a 0.7V output. As per the datasheet, a 10pF to 15pF feedforward capacitor (CFF) is recommended between the VOUT and FB pins for low output voltages.
However, I noticed that the DC1889A evaluation board uses a 100pF CFF.
Could you please confirm the recommended value of CFF for a 0.7V output in my case? Also, is there a formula or guideline to calculate the optimal CFF based on output voltage or other parameters?
Your clarification would be very helpful.
