LT1054 how well does the minus output match the plus input absolute value that is.
Product Number: LT1054
I don't see a spec on this in the data sheet. If I can get away with it I don't need to regulate since Vin is well regulated.
Am I mistaken here?
  • Hello,
    If you are trying to match the -VIN voltage then regulation will not help. The part will be running open loop based on the voltage loss from the input to output. The voltage loss does vary with load, oscillator frequency, and CIN (the flying cap). Below are the graphs from the datasheet illustrating what can be expected for a output voltage loss on a typical part.
