Whats input and what is output on this IC
Category: Datasheet/Specs
Product Number: LTC4020
Hi, I have a question regarding LTC4020 inputs and outputs. I didnt understand if the called Vout on page 38 of the datasheet is also where i'm suposed to plug whatever devices that i want to power. As far as I know, some synchronous buck-boost converters are bi-directional, so i was wondering if Vout is just for charging the baterry, and when theres no power source,  (Vin) turns to be the new output of the converter, using the battery as energy source and converting it to whatever voltage is required.
summarizing:  when using the battery as power source, where do i connect the device i want to power?
this is the datasheet im following: LTC4020 (Rev. E)
thanks in advance.
