Our customer is using LT8722 but any problem is occurred.
First, it is PWM signal output when SWEN is low and SWEN_REQ=0.
If you know any causes, please tell me that.
We are thinking the PWM signal should not be output in the condition of SWEN is low and SWEN_REQ=0.
In 2nd problem, he is set the blow registers as the default of his application.
address=00, data=0008bb03
address=01, data=00000001
address=02, data=000000e2
address=03, data=0000011e
address=04, data=00000000
address=05, data=00000005
address=06, data=00000000
address=07, data=00000000
It is occurred SD(TSD, CP_UVLO) if he change register address=04(SPIS_DAC) during using PWM signal.
Please tell me the reason of above problem occurring.
Does LT8722 have any limitation at SPIS_DAC register use?
He would like to stop occurring SD or Fault because the application will be broken if SD or Fault will be occurred during operation.
In the 3rd problem, he is felt instability to LT8722 so LT8722 will be occurred SD or fault manytime in early time from started.
However, after a few time, the SD or fault will not be occurred manytime compare the time of just started.
In using LT8722, does he need wait from power supply turn on to start operation at a few minutes or more?
Best Regards,
Tomohiro
