Hi Everyone,
I am working on a power supply design using the LTC3896 to create a negative PSU with an output range of -5V to -55V at 3A. My typical input voltage is 10-12V.
Design Approach:
To enable flexible Vout, I plan to implement an MCU-based voltage set point by introducing a variable resistor (Rc) alongside the standard VFB resistors (as shown in the schematic). The modified configuration allows MCU control of Rc to fine-tune Vout dynamically.
Testing Setup:
For testing, I am using the DC2447A Evaluation Board (Analog Devices). I modified it by introducing Rc and an external regulated power supply (0-2.4V), which acts as my VDAC output from my Atmel MCU.
The voltage equation follows:
Issues Faced:
Current Limitation & Crash:
When driving a load, the circuit crashes beyond 1A, requiring a reset.
Despite achieving a wide range of Vout values, I encounter issues when the electronic load starts.
Electronic Load Behavior (EL 9000T):Series EL 9000 T Conventional electronic loads 400W up to 600W | Programmable DC Electronic Loads (conventional and regenerative) | Products | EA Elektro-Automatik
Using the EL 9000T Electronic Load, I notice a switch from CV (Constant Voltage) to CC (Constant Current) mode unexpectedly when applying load.
Potential Voltage Instability at ExtVcc and Vfb:
I suspect that voltage instability at ExtVcc may be affecting the system performance.
The modified feedback resistor combinations allow for a broad Vout range, but certain parameters may be affecting IC operation, possibly turning off the chip or impacting FREG stability.
Request for Guidance:
I would appreciate any insights on:
Potential stability issues with ExtVcc and ways to mitigate them.
Any additional parameters that could be influencing the chip's operation or causing it to shut down.
Recommendations to prevent current crashes when exceeding 1A load.
Any best practices to ensure VFB resistor selection does not inadvertently impact IC performance.
Thanks in advance !
Sal
