Hi ADI experts,
The datasheet shows that LTM4680 can be configured with a resistor to output voltage through the VOUTn-CFG pin without using any programming interface. As shown in Table 1 of the datasheet, only some discrete specific values are given in the table. Can you provide a formula for configuring the output voltage so that we can adjust the resistor to set the output voltage to any value, such as 0.85V commonly used in FPGA?
Regards
