Can it be configured as adjustable output voltage?
Category: Datasheet/Specs
Product Number: ADP150
There is adjustable output voltage configuration (voltage divider to gnd pin) mentioned in ADP151 datasheet, but not in ADP150.
It seems to me that ADP150 and ADP151 are basically the same but with different maximum output current limit.
I am wondering if it is just not included when publishing ADP150 datasheet, or somewhat the ADP150 is not recommended to be used in adjustable output voltage configuration?
(i am trying to select 3 different output voltage by grounding different resistor values)
best regards
c.h.
