So im designing a PCB with LTC4380 Surge stopper to switch and manage power. The control circuit is low current 5V system. The load is high current(~10A) 24V system. The load is very spikey and noisy so I have split the ground and I have two separate ground terminals on PCB for low and high current.
its a bit of a dilemma for me where should I place the required load capacitor.
a. Place it between MOSFET souce and analog ground
b. Place it between MOSFET source and power ground
Datasheet has the following to say:
- The concern with option a. is that the CL now provides a low impedance path from load to analog ground. Would that introduce high frequency noise into the analog circuitry and defeat the purpose of split grounds?
- The concern with option b. is that the current loop (as seen by the surge stopper) becomes too large, since the GND terminal of the capacitor is connected via a long external cable and could cause stability problems with MOSFET control.
The surge stopper is referenced to analog ground. Capacitors are low ESR ceramic.
