LT8582
Recommended for New Designs
The LT8582 is a dual independent channel PWM DC/DC converter with a power good pin and built-in fault protection to help guard against input overvoltage...
Datasheet
LT8582 on Analog.com
I need a +-15V converter. I have decided to use LT8582. For this, there is a application circuit in the datasheet. (Tracking ±15V Supplies from a 2.7V to 5.5V Input) I try to understand logic behind to connection FBX2 via 6.04k resistor to FBX1. Why we need this connection? Could you explain?
