Hi All,
I want to use the MAX891LEUA+T device. Regarding the delay of FAULT pin.
What is the delay between case of current limit or when the die temperature exceeds +135°C to FAULT pin change to low?
Moshe
MAX891L
Production
The MAX891L/MAX892L smart, low-voltage, P-channel, MOSFET power switches are intended for high-side load-switching applications. These switches operate...
Datasheet
MAX891L on Analog.com
Hi All,
Moshe
