TVS diodes for LT4320
Product Number: LT4320
Dear Sis at ADI Engineer Zone,
In the Demo Manual DC1823B and in the DC1902B, I see that there are two TVS diodes, one bidirectional at the input of the LT4320 and one unidirectional at the output.
I have to make a 20Vcc/1.5A virtually noiseless regulated power supply using a bridge with LT4320 (plus four Mosfets) and a voltage regulator LT3086. The transformer I have provides 15/17Vac 3A at the output.
Question: what brand and model of TVS diodes do you recommend to use for my power supply?
I had thought of an SMAJ26CA on the input and an SMAJ22A on the output but I'm not sure if this is the best choice.
I Thank You Very Much in advance for your kind reply and I am looking forward to hearing from you.
Kind regards,
Enrico Borsetti
  • Hello,
    My apologies for the delayed response. Assuming your 17VAC is in RMS, this is approximately 24Vpk. So you'll want a TVS that will not conduct at 24V, so something like the SMAJ26CA seems like a good choice. To simplify things, I would use the same voltage for the unidirectional output TVS, so a SMAJ26A. The SMAJ26A/SMAJ26CA's max clamping voltage is 42V, so I would make sure that your components are rated for an absolute maximum voltage of 42V.
    Best Regards,
    Eric
  • Dear Eric,
    Thank you for your reply.
    Yes, 17VAC is in RMS and all passive components are rated at max 50V. I'll follow your suggestion of SMAJ26CA at input and SMAJ26A at output.
    Thanks much for your help.
    Cheers,
    Enrico
