adi
Product Number: ADM1260
Hello, I am working with equipment that uses your product ADM1260, we use 3 per each equipment, I need to copy the sequence from good units to ones that have not sequence programmed, I am using the ADI power studio and tried with the option "save project" in a good unit then "open project" in the one that I need to program following I select compile and program from the icons on right corner, after that the icons goes gray and return in green color, it takes some time, but the unit still not programmed, is there a way to pass the sequence from one unit to another?
 Thanks in Advance
      Best Regards
