UV/OV Resistor Selection
Category: Datasheet/Specs
Product Number: LTC4365
Hello, I am using the LTC4365. When I am trying to figure out resistor values for this part I am running into a discrepancy in the datasheet. On page 11 of the data sheet, in the "Procedure for Selecting UV/OV External Resistor Values" section. It gives the formulas for selecting these R values.
In the example after, it does not seem to line up with these formulas... In "3." the R3 value is 1.82M? When it was just solved to be 2.74M? Is this the correct formula, or just an error on the datasheet? I tried simulating my circuit in LTSpice (UV = 5.5V, OV = 8V). By using the formulas above I got R3 = 3Meg, R1 = 206.27K, R2 = 93.75K. My simulation isn't turning on when I ramp the voltage from 0-20V.
Any help would be appreciated! Thank you!
