Hello!
I would like to control of Enable pin with 3.3V MCU for LT3094.
I don't know how to control transistor or FET in negative voltage situation.
Could you please show the example circuit?
Thank you!
LT3094
Recommended for New Designs
The LT3094 is a high performance low dropout negative linear regulator featuring ADI’s ultralow noise and ultrahigh PSRR architecture for powering noise...
Datasheet
LT3094 on Analog.com
Hello!
Thank you!
Hi. The LT3094 datasheet text below says EN/UV can be driven by a positive signal. Just provide a 3.3V signal from your MCU to EN/UV when you want the LT3094 to turn on and then provide 0V from your MCU when you want the LT3094 off.
