Hello, I'm building a constant-current driver for several hundred LEDs and I plan to use several LT3760 to drive them.
My problem is that i have limited pins going to each board of LEDs and I can't run separate LED+ lines from each IC. All 1500 LEDS must have a common LED+ voltage.
Can I combine LED+ lines from each boost converter? That doesn't seem like it would work.
I am not worried about efficiency, can I eliminate the boost converter entirely and power the LEDS directly from V+ of the power supply?
