LTC4364-2 MOSFET M1 Failure
Product Number: LTC4364
Hi Team,
We are using LTC4364 IC in a surge protection circuit as given below.
V(IN): 48V
V(OUT): 48V upto 7.3A load
Selected MOSFET part number is marked in the given circuit image.
Surge Protector Circuit
The circuit works fine at the start but over a long run (say one or 2 months), we are facing MOSFET burning out issues. We cannot find the root cause of this issue.
Would you please look into it and direct us towards the solution?
Harish I I
  • Q1 needs the Safe Operating Area (SOA) performance to survive 4 situations:
    1. Start-up. Inrush current is controlled by slowly slewing Q1. Ease SOA stress using ENOUT to keep Load off until Cout is charged.
    2. Hard Short. (Current limit folded back to 50%)
    3. Soft Short. (100% Current Limit)
    4. Input Surge (Vin rises to max Vin during full load).
    There are previous posts detailing the calculations for these 4 points.
    Size the TMR cap to stay within the FET's SOA.
    You can use LTspice to see the exact timeout in situations 2-4.
    I suspect the FET fails during start-up. Use the ENOUT feature.
  • When I observed the MOSFET failure, the PCB area around the MOSFET was black and seems to be delaminated due to heat. I think this kind of damage will not happen in an instant. It should be because of a prolonged stress. Hence, I cannot assume that the failure is at the start up.
    Also, we are testing with a resistive load and there is no Cout.
    So, what could be the possible reason for the failure?
    Could you please help us find the root cause.
    Startup is a common cause of failure, since there is VDS across the FET while the output cap charges and the load draws current. I*V=P.
    I see 22uF of output cap in your schematic. Of course the resistor also contributes to stress during startup.
    It's one of the 4 situations I posted.
    I suggest plotting these points on the FET's SOA graph.
    The FET needs to be able to survive each situation, and if it does, the FET should not fail.
