TMR charging current specification of LTM4656
Category: Datasheet/Specs
Product Number: LTM4656
Hi
I'm planning to use LTM4656. Please let us know below query.
Regarding TMR charging current, it mentioned "The TMR charging current increases linearly from 8µA with VDS < 0.5V to 120µA with VDS = 40V. VDS is inferred from the drop across VIN and SENSE1. See Figure 1." in FAULT TIMER SECTION. Also, same information is writing in Figure 1. However, Figure2 mentioned ITMR = 120uA at VDS = 28V. According to the above comment, ITMR = 120uA at VDS = 40V is ideal value.
Please let me know why these value is difference?
Regarding the TMR OVER I in ELECTRICAL CHARACTERISTICS, How should I calculate this value?
I thought TMR OVER I = tFLT. if so, it can calculate below formula. However, it doesn't match.
TMR OVER I (5V) = 800 us(TYP)
tFLT = 0.01uF * ((1.275V - 0.5V) / (ITMR = 20uA at VDS = 5V)) = 387.5 us
Best regards
  • Regarding 25mV SENSE in FOLDBACK TIMER, I think 25mV sense is fault condition from datasheet, also,  FOLDBACK is a current limiting technique to limit the peak power dissipation to prevent thermal destabilization or thermal runaway in the power transistor to keep it in its SOA (Safe Operating Area). if so, I think this time is from reached 1.275V on TMR to TMR to be 0.5V after reached 4.3V on TMR. is it correct?
    An internal amplifier limits the voltage across the internal 4mΩ current sense resistor to 50mV. This is reduced to 25mV in a severe fault when BVIN is below 2V. In this fault condition, a timer is started inversely proportional to MOSFET stress. Before the timer expires, the FLT pin pulls low to warn of an impending power down. If the condition persists, the MOSFET is turned off, and restarts after a cooldown period. BVIN needs at least 100µF capacitance to service proper current limit level to eliminate any overtemperature timeout oscillations
