How do I get the MAXM17225AMB+T to go into Ultra-Low Quiescent Current mode.
Product Number: MAXM17225AMB+T, MAXM17225
I was wondering how to get the MAXM17225AMB+T into Ultra-Low Quiescent Current. I assume the enable pin must be held low. Still, nothing in the datasheet confirms how to do this other than what the datasheet says about the RSEL resistor, which mentions that the device can use less current when setting up to output the required voltage and thus has an Ultra-Low Quiescent Current.
I have measured that when a load is attached to the output of the MAXM17225AMB+T, the device draws around 30-50 mA of current when the output is enabled. When the load is removed, or you pull the enable input low, the device goes into low-power mode.
Any help clearing up the datasheet for the  MAXM17225AMB+T would be greatly appreciated.
