Good Afternoon to whom it concerns,
I am creating/designing two SWMPS circuits to do two things:
- take +5v and buck to -5V
- take +5V and buck but then boost to -15V
I have LTC3879 already from a previous project and want to reuse the chips.
I was hoping to learn from Analog Devices what considerations are important to my MOSFET selection for the Hi side and Lo Side switches to achieve the best efficiency with the LTC3879.
For example,
To get -15V, The duty cycle is on for one gate more than the other gate and so is it true i should have a lower Rds(on) for the switch that remains on the longest but consequently a higher gate charge and then the second switch to have a higher Rds(on) but a lower gate charge to get the best efficiency?
To get -5V, is it more efficient to use the same MOSFET as the duty cycle is equal on both switches so choosing a lower Rds(on) for both switches is best? For this circuit i will use the same circuit as per the datasheet on page 25 that uses the same pair of MOSFET.
Any support is appreciated, Please do ask questions that can help the query.
Kind Regards,
Jordan W
