MAX20034
Production
The MAX20034 is an automotive 2.2MHz, dual synchronous step-down controller IC that provides two high-voltage, synchronous step-down controllers that operate...
Datasheet
MAX20034 on Analog.com
Can the two outputs of MAX20034 be connected together and used as multi-phase single-output?
What extra attention should be paid to this usage scenario?
Our application has a large output current(~30A) and requires a good dynamic response, so we want to use a multi-phase primary power supply
Please help confirm. thanks.
The IC isn't inherently designed for multi-phase operation, but because the channels are conventional current-mode-regulated supplies, you could probably parallel the phases. You would need to tie the FB pins together, tie the COMP pins together, and adjust compensation accordingly.
Thanks for your confirmation.
Is there any potential risk in this usage?
The biggest risk is sub-optimal current-sharing between channels. Tying the channels' control lines together (as mentioned previously) should help avoid drastic imbalances, but it will likely not be as well-matched as regulators designed for multiphase operation.
The best approach would be to acquire an EV Kit and test it out on the bench.
