Trouble with the device outputting the required voltage based on RSEL.
Product Number: MAXM17225AMB+T, MAXM17225
The component works when no load is applied to the output voltage and when the voltage input starts low enough, typically around 0.9 Volts. The output works if the voltage input is above 1.3 Volts with no load. If the voltage input is above 1.1 Volts with a load, the output doesn't work.
When using the MAXM17225 Evaluation Kit, we could connect it to our device and it worked no issue, but when we tried using the same component on an external board and connect it to our device it would only work under certain circumstances listed above.
RSEL = 56.2 kΩ
Battery Input = (0.8 Volts to 1.3 Volts)
Scenarios: (Desired Output = 3.5 Volts)
VBAT = 0.9 Volts / MAXM17225AMB (Out) = 3.5 Volts / Load Connected (330 Ω)
VBAT = 1.1 Volts / MAXM17225AMB (Out) = 1.8 Volts / Load Connected (330 Ω)
VBAT = 1.2 Volts / MAXM17225AMB (Out) = 1.8 Volts / Load Connected (330 Ω)
VBAT = 1.3 Volts / MAXM17225AMB (Out) = 1.8 Volts / Load Connected (330 Ω)
VBAT = 1.3 Volts / MAXM17225AMB (Out) = 3.5 Volts / No Load Connected (330 Ω)
When it comes up in the failed state (1.8 Volts Out) and the load is removed, it comes up to 3.5 Volts.
Any help would be greatly appreciated!
