Can I leave G1/G2 floating if I'm not gonna use switching over?
If no, what should be it's state?
Thanks!
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
LTC2953
Recommended for New Designs
The LTC2953 is a push button On/Off controller that manages system power via a push button interface. An enable output toggles system power while an interrupt...
Datasheet
LTC2953 on Analog.com
Thanks!
Hi ntenorio,
LTC2953 does not provide a switchover feature for multiplexing 2 supplies. Perhaps you're referring to LTC2952?
If that's the case, G1 and G2 can be left floating if you won't be using the primary and secondary ideal diode function for switchover.
