LT8306
Recommended for New Designs
The LT8306 is a micropower isolated flyback controller in a 6-lead ThinSOTâ„¢ package. By sampling the isolated output voltage directly from the primary...
Datasheet
LT8306 on Analog.com
LT8309
Production
The LT8309 is a secondary-side synchronous rectifier driver that replaces the output rectifier diode in a flyback topology. By replacing the diode with...
Datasheet
LT8309 on Analog.com
I'm simulating LT8306 and LT8309 in LTspice but can't get them successfully start up. The circuit is from Figure 30 in datasheet.
I guess it's the same reason with this thread LT8306 - Stops Switching but don't know how to fix it. I wonder if it's caused by the soft-start short circuit protection and could you help get the model running. Thank you.
Kind regards,
Cain
