LT3065 current source: max SHDN switching freqeuncy
Product Number: LT3065
I would like to use the LT3065 as a current source for a led and I am basically replicating this circuit
I removed the Cref capacitor to decrease the transient time
However I am finding a too low turnoff time ( yellow pin SHDN and blu is ADJ pin)
What is the max switching frequency of SHDN? I need to go up to 10KHz
Do you know why this is happening?
  • Hi.  I am worried the LT3065 won't be able to turn on fast enough for a 10kHz on-off rate.  Plus, you noticed the LED current decays slowly, probably as the 10uF discharges through the 6 Ohm and the LED.  Below in the image I show in LTspice a way that the LT3092 current source can easily turn on and off at 10kHz.  There are other reference designs in the LT3092 datasheet that are similar current sources.  Can you consider the LT3092?  I attached my LTspice file.
    sim ckt and result_1.pngLT3092_1.asc
