LT8602 - What to do with SYNC pin?
Category: Datasheet/Specs
Product Number: LT8602
The LT8602 datasheet says this about the SYNC pin:
Clock Synchronization Input. A digital input to allow the LT8602 to synchronize its switching frequency to an external clock. If clock synchronization is not used, connect this pin to ground to enable low ripple burst mode or connect high to enable pulse skip operation of the synchronous converters. Do not allow SYNC to float.
I do not want to use an external oscillator, nor do I want to be in burst or pulse skip mode, I want to be in standard operating mode with no bursting or skipping. What do I do with the SYNC pin to be in standard operating mode?
Thanks!
