LT8618
Recommended for New Designs
The LT8618 family are compact, high speed synchronous monolithic step-down switching regulators that deliver up to 100mA to the output with high efficiency...
Datasheet
LT8618 on Analog.com
The ADI article link I am wanting help with can be found here: https://www.analog.com/en/resources/technical-articles/how-to-get-the-best-results-using-ltspice-part-1.html
I've also attached the buck converter LTspice schematic below.
What I am wanting to learn more about is:
I like the idea of using a LISN within LTspice and implementing limit lines to see conducted EMI assuming you model your system correctly.
I follow the article well up until figure 7, where the figure shows the input voltage source now pulsing with some format into the LISN, where the LISN also connects to the input of the LT8618.
Regarding my point number 1, I don't understand why the input source to the LISN changed? Can you help me set up the LISN within my attached circuit?
To my point number 2, my understand of designing an input filter is I first need to know the amplitude of the harmonic or FFT plot at the switching frequency, then design the filter based on the needed attenuation. I'm not sure where to start though for getting that amplitude within LTspice, can you help me along with this process?
Why has no ADI support taken place? It's been 15 total days.
