Voltage sequencing
Product Number: LT3514
Hi.
I would like to ask if somebody has implemented voltage sequencing using LT3514. Looking at the datasheet I can´t figure out how to implement voltage sequencing so when the first output voltage has reached the programmed voltage, the second output will be activated and when this second output voltage is ok, the third output will be active.
Thank you in advance.
