Transient Output voltage simulation
Product Number: LTM8068
Dear Engineers,
I have an issue with LTM8068 DC/DC converter, that is as i  run tranisent simulation with input of 28VDC
given that I choose the resistors values as specified in the datasheet, the output doesn't settle at 5V
it increase to higher values with transient time is 50ms.
ltm8068_test.asc
  • Hello Nawaf,
    the LTM8068  requires a minimum load to stabilize the output voltage. See the corresponding chapter on page 14 and the correspondig graph on page 6 of the datasheet.
    In your simu, you have not load at all at the output. Add the required minimum load (e.g. 500 Ohm between Vout1 and VoutN), and the output will stabilize at the intended voltage.
    best regards
    Achim
