MAX16165ATPH T
The user identified two errors in the calculations for selecting feedback resistors and offset current for the SET pin: R_ios should be 100 kΩ instead of 10 kΩ, and the correct formula for R_2 is R_2 = R_1 × 0.5 / (V - 0.5V). The support engineer confirmed the corrections and provided an updated calculation diagram.
Category: Datasheet/Specs
Product Number: MAX16165ATPH+T, MAX16165
Selecting SET_ Feedback Resistors and Offset Current
While tunning resistors values for SET pin I notice two errors:
  1. The R_ios resistor value in the calculations is wrong, it should be 100 Kohms instead of 10 Kohms
  2. The formula for calculating R_2 is wrong, in the first occurrence, the formula is: R_2 = R_1 × 0.5 / _ but below the formula is R_2 = R_1 × 0.5 / (_ - 0.5V).
According to this, after testing the IC the good formula is the second one
