LT3581 in a Symmetrical DC/DC Configuration - Oscillations
Product Number: LT3581
I have used the LT3581 to create a symmetrical DC/DC converter from 11-20V to ±38V, 300kHz based on the application note "1MHz, ±12V Charge Pump Topology Uses Only Single Inductor."
With L = 68µH, RT = 274k, FB = 442k
It works correctly, but since my load is very low, less than 10mA, it operates in DCM (Discontinuous-Conduction Mode), which creates oscillations of a few MHz. My application is very sensitive to these frequencies, so I tried to eliminate them by adding a snubber circuit with R = 1k and C = 68nF on SW1 pin to GND.
Before Snubber Circuit:
After Snubber Circuit:
However, because the Duty Cycle period during conduction is fast, a few MHz, I still have noise. I then increased the inductance to 220µH, the maximum I can use given my footprint, to increase the Duty Cycle period during conduction, which allows me to reduce the Duty Cycle period to 600kHz. Nevertheless, with 220µH I exceed the recommended Lmax in the Datasheet formula.
My questions are:
  1. Does the Lmax formula apply to this setup, and if so, what are the consequences of exceeding it?
  2. Is my snubber circuit correct?
  3. Is there another way to reduce sub-harmonic oscillations?
Thank you in advance for your help!
Jérémy
Edit Notes
tag removed
[edited by: JBO at 1:12 PM (GMT -4) on 14 Jun 2024]
