The engineer I am working with says Pin 13 (center pin) s/b connected to ground and not pins 1 and 2 like the data sheet. Is pin 13 connected to pin 1 and pin 2 internally or can we connect it to ground.
Strong EMC design
LT3094
Recommended for New Designs
The LT3094 is a high performance low dropout negative linear regulator featuring ADI’s ultralow noise and ultrahigh PSRR architecture for powering noise...
Datasheet
LT3094 on Analog.com
If you don't mind, I would like to refer you to this post that discusses the same issue for a similar negative LDO - the LT3090. The title of the post is "LT3090EMSE's exposed pad connection".
