Minimum AC voltage for operation
Category: Datasheet/Specs
Product Number: LT4320
What is the minimum AC voltage that LT4320 can operate?
In the datasheet it is stated as 9V but it is not clear if it refers to RMS or peak voltage.
Thank you
  • Hello,
    Due to an issue with EZ I did not receive notifications for this post. My apologies. I understand this reply is likely too late to be useful for you. In case anyone else has a similar request, I will answer your question.
    The 9V minimum is the rectified OUTP to OUTN voltage. The minimum VAC voltage depends on the output capacitance, frequency, and load but it could be as low as 6.5VAC.
    Best Regards,
    Eric
