lt8316 - Output Voltage Drop
Product Number: LT8316
Hello Everyone, hope everything is good with you.
I am designing a voltage regulator, identical to DC2781A.
I just changed the MOSFET, I am using STD6N90K5 from STMicroelectronics.
I have designed the PCB and it worked, at least it managed to get a stable output with a load of 1mA (board LED). However, if I plug more load it just drops:
- 10k resistor made the output fall to 7V
-1k resistor made the output fall to 1.7V
Do you have any idea of what could it be?
I already have tested the board up to 550V and it kept the output well regulated with the LED.
My PCB is open to everyone since it is used for a Formula Student, so if better, you can check the Altium design here (Release v2.0.0): github.com/.../T24_VoltageIndicator_Hardware
Circuit Below:
PCB Below:
