LTC2945
Recommended for New Designs
The LTC2945 is a rail-to-rail system monitor that measures current, voltage, and power. It features an operating range of 2.7V to 80V and includes a shunt...
Datasheet
LTC2945 on Analog.com
Hello Team,
We are trying to Read the Voltage through the LTC2945 chipset.
Whenever we are reading the controller register 1e and 1f we get the random error like " Read failed or Resource is temporarily unavailable".
This is a critical parameter for our application kindly suggest us some solution for this issue.
GLADION - Moved from Amplifiers to Power Management. Post date updated from Tuesday, April 23, 2024 11:20 AM UTC to Tuesday, May 28, 2024 12:34 AM UTC to reflect the move.
Thank you for your question. I am reviewing the information you provided and may come back with follow up questions. I appreciate your patience as I work on your query.
Gilbeys
As far as resources being unavailable, there is a busy bit in the CONTROL register, but that only affects snapshot mode. I suspect that the issue may lie in your code, as natively, the part has no "resource temporarily unavailable". Can you get a scope shot of a failed transaction please?
Thank you and best regards,
Brad
