Customer would like to know whether part EVAL-LT8374-AZ can switch the frequency externally.
If not, please help to suggest any part with this function.
Thanks
Regards
LT8374
Recommended for New Designs
The LT8374/LT8374-1 is a high efficiency, monolithic, synchronous step-down DC/DC converter with fixed-frequency and peak current control. The LED current...
Datasheet
LT8374 on Analog.com
Thanks
Regards
Please help to advise any status for the above.
Thanks
Regards
Hi glyeo ,
It seems like you can change the frequency only by replacing the chip with LT8374-1 (2MHz).
Wondering, what is the problem with the 330kHz?
A suggestion of substitute chip would require more information about your application.
Cheers, hekea
