LT8636 spurious
Product Number: LT8636
I am seeing a significant spurious output signal at 220 KHz on the output of the LT8636 switching regulator. The device is configured for spread spectrum mode with a switching frequency of 2 MHz. The input voltage is +12V, output is +6V with 1.5A load current. If you look carefully at the Conducted EMI Performance plot on p. 11 of the data there are at least four discrete spurs below 1 MHz. Is this to be expected? Are there other Silent Switcher parts without these extra spurs? I also don't understand the amplitude units of dBuV/m for the conducted output. This looks like a radiated field strength measurement.
Edit Notes
Note: I think my problem may be pcb layout related. Unlike on the eval board, I failed to locate the two Vin capacitors close to pins 6 and 11.
[edited by: StanZ at 5:24 AM (GMT -5) on 4 Jan 2024]
