LT3790: output voltage drop
Product Number: LT3790
Dear all,
I am using the component LT3790 to generate an output voltage of 32Vdc.
Unfortunately, the output voltage every 2.4s has a voltage drop to 0V for 13.5ms and then returns to 32V. The load was only 300mA.
In this case the system had the following data:
Input voltage: 16V
Output voltage: 32V
Output current: 0.3A
Switching frequency: 481kHz
EN/UVLO: R1=330k, R2=27k (should be UVLO-=15.87V, UVLO+=17V)
My idea is that I should decrease the EN/UVLO threshold changing the resistor R1=470k, R2=75k (should be UVLO-=8.72V, UVLO+=10.24V).
May my problem come from another reason?
Thank you very much for your support.
Best regards
Andrea
