The data sheet says part has thermal shutdown, but does not specify the threshold. Can you confirm it does have thermal shutdown and what is the threshold?
mark
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
LT8631
Recommended for New Designs
The LT8631 is a current mode PWM step-down DC/DC converter with internal synchronous switches that provide current for output loads up to 1A. The wide...
Datasheet
LT8631 on Analog.com
mark
datasheet states this:
Honestly there is no need to spec a detailed OT threshold, because you should not design the part with this threshold in mind. It's there to prevent catastrophic failure, but it's not there to be a 'valid' state of operation. Aim for a design that will be safe to operate in all intended conditions depending on ambient temperature, maximum Vin and Iout.
The H-grade is specced for 150C junction temperature so the OT trip point will be at higher temperatures.
