MAX77950 LC Tank Design
Product Number: MAX77950
The datasheet for the MAX7950 only lists a "Typical Application Circuit" where the LC tank is 4x100nF parallel capacitors in series with an 8uH coil. Pencil-whipping the math shows it should be resonant at ~89kHz, which is less than the WPC default frequency of 125kHz. My question is: is there something special about this frequency, or are the values chosen with component tolerances in mind (if both the coil and the capacitors are 20% tolerance, resonance would be at most 111kHz)?
Is there a hardware design guide for the MAX77950? Most datasheets I've found have formulas for using values other than those in the provided application circuit ...
  • Aloha megaman24
    Thanks for your LC Tank Design question. I have question too.
    Earth ICT, SPC has a license to make, have made, use, and sell ... basically an LC Tank with invention added Transformer(s) ... LCT Tank/Reservoir...
    Oscillator for adiabatic computational circuitry
    Oscillator for adiabatic computational circuitry (US11671054)
    Granted Patent | Granted on: 2023-06-06
    https://labpartnering.org/patents/US11671054
    An adiabatic resonator, an adiabatic oscillator, and an adiabatic oscillator system are disclosed. An adiabatic system is one that ideally transfers no heat outside of the system, thereby reducing the required operating power. The adiabatic resonator, which includes a plurality of tank circuits, acts as an energy reservoir, the missing aspect of previously attempted adiabatic computational systems. By using the adiabatic resonator as a feedback element with an amplifier, an adiabatic oscillator is formed. An adiabatic oscillator system is formed with a primary adiabatic oscillator feeding a plurality of secondary adiabatic oscillators. In this manner, the adiabatic oscillator system may be used to generate the multiple clock signals required of adiabatic computational logic elements, such as Split-level Charge Recovery Logic and 2-Level Adiabatic Logic. The adiabatic oscillator system stores enough energy to drive many individual adiabatic computational logic elements, permitting implementation of complex logic circuits.
    Mahalo, Art; adiabatonaut42; Founder, Director, CEO Earth ICT, SPC
