I have a weird issue. I'm using all the regulators on the LT3383 with a common input voltage of 5V just like the reference design in the datasheet. I suspect all three LDOs are at their top current limit of 300 mA. Each one of them is dissipating about 1 Watt of power raising the temperature of the chip to above 70C. When I switch on the Buck regulators of the LT3383 with some memory chip loads I get some huge in-rush enough to trip the 5V source. When I reduced the input voltage source of the LT3383 from 5V to 4V and applied the same loads on the BUCK regulators the in-rush just went down by at least 0.5A. Does that make any sense?
