Suitable Multiphase Controller IC for Buck Converter
Product Number: LTC3871
I am a Power Electronics Engineering working on a system with the following specs;
Vin = 48 VDC (unregulated)
Vo = 30 VDC (tightly regulated)
Max Output Current = 100 A
Max Switching Frequency = 100 kHz
Mode of Control: Voltage Mode Control
Non-Isolated unidirectional topology with Duty-Cycle Control
I have found the following Multi-Phase Buck Converter Controller ICs that can be used in our system. Which one do you recommend ? We plan to use two phases in our system.
  1. LTC7810
  2. LTC7871
  3. LTC7872
  4. LTC3871
Thanks for the help.
Regards.
All of the controllers you listed are current-mode control.
With that said, I think it will be hard to find suitable components if you decide to use a two-phase design. You'd need 50A per phase, and with a low switching frequency(100kHz), I would expect the inductor to be bulky.
I would recommend using the LTC7872/LTC7871. The difference between them is that the LTC7872 is four-phase while LTC7871 is six-phase.
I'd suggest ordering the demoboard for the LTC7871 and try to tweak the demoboard to your design.
DC2886A Evaluation Board | Analog Devices
Jhun
  • Dear Jhun,
    Thank you for a quick reply.
    I will review the Evaluation Board and will try to create the simulation model of our system using LTC7872 in LTSpiceCAD and LTSpice. I will let you know if I have questions.
    Regards.
  • Dear Jhun,
    I have studied the data sheets of LTC7810, LTC7871 and LTC7872. I agree with you that 4 or 6 phases make more sense but it will increase the size of converter as there will 4 or 6 inductors and 8 or 12 Electrolytic Caps. I am more inclined towards LTC7872 as it has 4 phases, so there will 25A per phase.
    I have a few questions:
    a) I wanted to run some simulations first to get rough efficiency numbers. However, I could not find the models for LTC7872 in both LTSpice and LTPowerCAD. I have updated both the softwares but still this model is missing. Do you know if the models for LTC7872 are available or not ?
    b) How accurate are the efficiency estimation and Closed loop performance of systems designed in LTPowerCAD ? I have designed a 2-phase Buck Converter using LTC7810 in LTPowerCAD and then verified the converter operation in LTSpice. I have attached both the models here. Surprisingly, the power-stage efficiency (including semiconductors, magnetics and capacitors) is higher than 97% at full-load. How close will it be to the actual hardware's efficiency ?
    c) Is there a way to limit the inductors currents during the Soft-Start ? Please see the currents in the attached LTSpice simulation file ? The inductor current during steady-state is lower than the current during the Soft-Start. I tried to increase the Soft-Start time, but it did not work.
    d) I can see the simulation model for LTC7871 is available in LTSpice. Can I use only 4 phases in it to imitate LTC7872 ?
    Thanks.
    LTC7810_Design.zip
  • Hi Jhun,
    Can you please respond to my question ? I am in the process of finalizing the controller IC for my circuit. I want to simulate the converter first to make sure it meets the efficiency and dynamic performance requirements.
    Thanks.
  • FormerMember
    FormerMember on May 31, 2023 7:14 PM in reply to zuzahid
    0
    Sorry for the delayed response as I was on leave.
    LTC7872 is not yet available. I would suggest that you use LTC3871 as an alternative for LTPowerCAD calculation as they are the same product family (difference is LTC3871 is two-phase and has integrated driver in the IC). Just design it for 50A (25A per phase still).
    The efficiency of a buck converter is pretty high. However, all parasitics can't be accounted for but the LTPowerCAD has a good estimate on efficiency.
    Start-up current/soft-start current being higher than the steady-state current is expected and a normal behavior. I don't think that you can mitigate this.
    Yes you may. The simulation should still work when using 4 phases only. I suggest that you still populate the sns+ and sns- for the unused phases to ensure it will work.
    Jhun
