MAX77962 I2C setting for currents won't work
The user had issues setting current and voltage values on the MAX77962 registers 0x18, 0x1A, and 0x1E over I2C. The solution was to unlock the protected registers by writing 0x0C (0b1100) to the CHG_CNFG_06 register (0x1C). The user confirmed that this resolved the issue, allowing them to set the current values.
Product Number: MAX77962
I have problem with my MAX77962 to set current and voltage values on different registers, such as 0x18, 0x1A and 0x1E registers. I followed the same circuit as the in datasheet to control settings over I2C. So, I pulled-up the VSET, ISET, INLIM and ITO pins to PVL with a 1K resistor. The entire circuit works fine. That means it charges my 2Cell battery when input current, VBUS, is set at 500mA (which is the default). I am trying to increase this current together with charging current using both I2C commands and pulling-down with a resistor. But none of them will change the current.   As for I2C, it seems I have to set the  FSHIP_MODE = 0 (which is already 0) and COMM_MODE = 1. For the later one, when I read the register value it's 0x05. But I wrote 0x85 to enable I2C mode. The value is still 0x05.
I would like to know if I have missed anything in my code and settings that none of my writing to I2C works. By the way, I only see writing to DISBIS bit effective as it disable/enable the charge cycle.
Thanks Amir
  • Is there anyone here to answer this problem??
  • Hi Amir, your question actually helped me find the solution! By default, most registers on the MAX77962 are locked from writing. This is due to the CHG_CNFG_06 register that contains the field CHGPROT in bits 2 and 3 that locks "Protected registers from writes". Writing 0x0C (0b1100) to the CHG_CNFG_06 register (0x1C) will unlock those registers for writing!
    Mason
  • Sorry for late response. Yes, I could set the current settings after enabling that bit. Please accept the lack of information about this register. If you search this CHGPROT in the document you will find no clear information that this bit will lock or unlock what kind of registers.
    For the charge and input current registers, I did not find any information that these registers are locked/unlocked by the CHGPROT bit. Please correct me I am wrong.
    Hope the document get a correction revision to be more clear. To be honest, I spent more than 3 days figuring out what is wrong with my circuit.
    Thank you again for your immediate and clear response.
    Amir
