I'm a DFAE in Japan. Our customer evaluates LT1054 and gives us a a question. What is the absolute max voltage of Vout pin?
Hiroyuki
LT1054
Production
The LT1054 is a monolithic, bipolar, switched-capacitor voltage converter and regulator. The LT1054 provides higher output current than previously available...
Datasheet
LT1054 on Analog.com
Hiroyuki
We typically do not spec the output because it is something that should come from the part. However loads can sometimes pull the output up. VOUT should be typically between 0.3V to -16V.
