Hello folks,
I hope I am in the right forum here.
I am developing a handheld device and want to use the MAX17271 Buck-Boost Regulator as a power supply.
The device will be able to be turned on by a switch. The state of the switch can also be read out via I2C.
A forced shutdown after 13 seconds of operation is also provided.
All this works fine.
Now to the problem:
How can I switch the device off again immediately via I2C, or otherwise? I did not find a hint in the documentation.
The 13 seconds forced shutdown is not a good option for a handheld device. (Only in case of a malfunction - and I'm sure that's what it's designed for).
Does anyone have any experience with this problem?
Edit Notes
added tag[edited by: emassa at 6:56 PM (GMT -5) on 22 Feb 2023]
