Have a problem with the output voltage of the charge pump circuit, LTC3261. The output is lower than expected
Product Number: LTC3261
The circuittis as the one in the data sheet with the following components
CGA5L2X8R1E105K
Cap Ceramic 1uF 25V X8R 10% Pad SMD 1206 +150°C Automotive T/R
LTC3261MPMSE#PBF
High Voltage, Low Quiescent Current Inverting Charge Pump, 4.5 to 32 V Vin, 12-pin SOP (MSE-12-EDP), -50 to 150 degC, Pb-Free
C3225X8R1E106K250AC
Multilayer Ceramic Capacitors 10uF ±10% 25V X8R SMD 1210
The output voltages are as follows:
LTC
Temp
VIN
IIN
VO
TPlane
18oC
12V
40mA
-11.06
19.6
70
12V
40mA
-10.9
69.8
80
12V
40mA
-10.88
80.4
90
12V
40mA
-10.84
90.5
100
12V
40mA
-10.83
100.9
110
12V
40mA
-10.8
111
120
12V
40mA
-10.76
120.8
130
12V
40mA
-10.72
130.7
140
12V
40mA
-10.68
140.6
150
12V
40mA
-10.63
150.4
Can you please tell me why the output voltage is not the inverse of the input voltage.
  • Hello,
    The open loop resistance of the LTC3261 does get higher with temperature. The output voltage is about -(VIN - IOUT*ROL) where ROL is the open loop resistance. Below is the open loop resistance over temperature.
    With the temperature near 150°C the open loop resistance is close to 50Ω. This will create a voltage loss of about 2V. I would expect the output voltage to be about -10V with a 12V input and 40mA. At 18°C the open loop resistance should be over 30Ω. I would expect the voltage loss to be greater than 1.2V and the output voltage would be less than -11V in amplitude. These numbers are slightly better than what I would expect.
  • Thank you. That answers my question.
