Dear all,
Could I used the LTC4085 as Li-polymer battery Charger?
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
LTC4085
Production
The LTC4085 is a USB power manager and Li-Ion battery charger designed for portable battery-powered applications. The part controls the total current used...
Datasheet
LTC4085 on Analog.com
Dear all,
Generally, yes, since the part is applicable for Li-ion batteries. Both batteries use a Constant Current/Constant Voltage charging sequence. The part can be used as long as the charge current levels and termination voltage matches the battery specifications.
Nino
