Hello, for a very noise sensitive design I plan to use an high PSRR LDO regulator to generate 3.3V and 5V
I need to have the option for more current and better heat distribution but it is very important to keep the high PSRR performance.
Do is possible to parallel multiple ADP7158 / ADP7159 or can you suggest an alternative that I can parallel also using an op-amp?
The voltage I plan to generate are 3.3v and 5V.
Thanks
