Please tell me (1) frequency range and (2) duty cycle range of PWM signal for dimming from outside.
Also, will (1) and (2) remain the same even if the switching frequency is low or high?
Kazu
LT3952A
Recommended for New Designs
The LT3952A is a current mode step-up DC/DC converter with an internal, 60V, 80mΩ DMOS power switch. The LT3952A is specifically designed to drive high...
Datasheet
LT3952A on Analog.com
Kazu
Hi Kazu,
LT3952A IC does not set limit of frequency/duty cycle range for external PWM dimming. However, with different applications and component selection, the PWM performance varies and has freq/duty limits in order to achieve good ILED waveforms. A good reference is datasheet page 26, 2MHz application can achieve 4000:1 150Hz PWM dimming, with ILED minimum pulse width 1.67us. My rule of thumb is if PWM frequency is 100-1kHz, minimum pulse width is around 5 switching cycles. If your application requirements are beyond the range, I would recommend testing and confirm.
Switching frequency of the circuit does affects (1) and (2). Actually (1) and (2) can be affected many factors like fsw, loop compensation, Cout, length of load cables, etc.
Gengyao
Hi Kazu,
Gengyao
