What is the max current that I can expect to get for this configuration, +9 Vin and -9 Vout? Based on the datasheet this exact configuration is not covered but looks like I should be good for 400mA.
LTM8045
Recommended for New Designs
The LTM8045 is a µModule® (power module) DC/DC converter that can be configured as a SEPIC or inverting converter by simply grounding the appropriate output...
Datasheet
LTM8045 on Analog.com
You should be able to get around 400mA for that configuration.
Jhun
What exactly is the limiting factor here?
Die temperature or something else?
The internal switches and inductor only have a certain amount of current that it can support.
Jhun
